Line led aft: how do you get the main down?
bscriver
Post by bscriver »
I am in the process of running lines aft to the cockpit. Ive only put the first pulley on the cabin roof, gave it a pull and my newly slugged sail shot up like greased lightning. I let the halyard go and the main only dropped 3' and it was no easier to drag the sail down with slugs vs the old rope. My plan is to abandoned the hope of moving my single line reefing back to the spin lock at the cockpit and leave it at the mast base and use the deck pulley I had planned for it, as some sort of a downhaul led to the the same spinlock as the main halyard. Anyone have another suggestion?
Re: Line led aft: how do you get the main down?
Getting the sail down and tied up still requires going on deck. So lines led aft is not perfect.
However, Jim King found a great solution that I'm going to adopt.
Here's a thread about it.
http://macgregor26x.com/phpBB/viewtopic.php?f=8&t=17434
Here he demonstrates the looped main halyard that also lowers the main.
http://s132.photobucket.com/user/c130ki ... 9.mp4.html
How about this...put the boat into the wind, climb up on the cabin roof and pull the mainsail down. :)
Plan B - get a FR for your main. 8)
bscriver wrote:I am in the process of running lines aft to the cockpit. Ive only put the first pulley on the cabin roof, gave it a pull and my newly slugged sail shot up like greased lightning. I let the halyard go and the main only dropped 3' and it was no easier to drag the sail down with slugs vs the old rope. My plan is to abandoned the hope of moving my single line reefing back to the spin lock at the cockpit and leave it at the mast base and use the deck pulley I had planned for it, as some sort of a downhaul led to the the same spinlock as the main halyard. Anyone have another suggestion?
Doug W
Post by Doug W »
I solved it with a "Down-Haul" (my term). Not a continuous loop like Jim King's but it works quite well.
I added three clutches. First Picture shows them. Inside white line is the daggerboard. Middle flecked line is my mainsail down-haul. Blue line on the right side is my mainsail halyard.
Second picture shows the blue halyard and flecked down haul runs to a double cheek block to blocks at the base of the mast and up to the same point at the top of the sail where the main halyard connects. I just use a bowline to connect it.
I had to add the BWY mast gate. With this set up, I rarely have to go up to the mast for sail handling.
Doug
sv Galacitca (leper, outcast, unclean)
Nice sunset picture tho. 8)
Doug W wrote: Doug
Don T
Post by Don T »
Doug W
Post by Doug W »
dlandersson wrote:Nice sunset picture tho. 8)
Doug W wrote: Doug
Chuckle :) That was in the Apostle islands on lake Superior 2 years ago...before she became a leper, outcasted and unclean... :P
If anyone has the ability to trailer to the Great Lakes, it's beautiful up there!
