Suggestions for Better Prop for the Honda BF50A
I have the standard prop that came with the Honda BF50A on my M26. Any recommendations for a prop improvement? Thanks, Eric
- DaveB
Re: Suggestions for Better Prop for the Honda BF50A
Do a search for Honda 50 in archives. I have commented on diffrent props. as many others have done.
- vkmaynard
Solas Amita 4 11.8 x 9
5900-6000 rpm - 15-16 kts
part # 3313-118-09
part # 3313-118-09
- Rick Westlake
Bossa Nova came to me with an 11-3/4 x 10, 3-blade prop. I broke one of the blades in a "stupid docking trick" and had to find a replacement. The local Honda dealer didn't have the same prop, but had a 4-blade 11-3/8 x 10 Honda prop - I took it.
On trials with the new prop, Bossa Nova got up to 15 kts @ 5500 RPM (GPS speed, ballast empty, upwind, forgot to check tide).
If you really want to "find the perfect pitch", consider a ProPulse propeller (http://www.propulse.jetshop.se). These are 4-blade, adjustable-pitch propellers with replaceable composite blades. According to the manufacturers, the correct prop for a Honda 50 is their Model 6902; it is 10.4" diameter, adjustable from 11" to 17" pitch. And if I'd had one of these when I made my stupid docking mistake, I could have replaced just the broken blade.
(Defender has it for about $20 less than West Marine.)
Eric,
Do any of these solutions create an improvement over what you have
If yes, is it/are they significant
- GeoffR
Gerry Berg in Vancouver BC recommended and supplied 12.25 by 10. Right rotation.
I have never been able to get above 12 knots GPS but my boat is fairly well loaded.
Geoff
The Dove
Geoff
