Major Repair - Replace Compression Post due to corrosion
Update - I cut the liner (two notches down the sole) and bent the liner
Removed two 9/16 SS nuts (they run down onto studs
which thread into the fiberglass centerboard trunk - interesting) on lower board
Removed two 1/4 inch nuts and one 9/16 bolt under mast step.
Bumped pole sideways and it slid out.
Elapsed time 20 minutes. Hardest part was getting the stopper knot out of the CB line...this needs to be replaced by the way.
Now the compression pole can make its rounds to my welding and corrosion experts
...in my mind, no matter what the outcome, my boat is 20 minutes from being back on the water once I have a compression post in hand either new or fabbed locally....
- tangentair
interesting, you did not mention anything about corrosion/eroding on the threads, looks more and more like a bad weld. I talked to a hull tech at the Navy Base about welding and learned it is really a lot more than just striking an arc.
Anyway, glad to hear it wasn't as bad as some may have imagined.
- tangentair
No conversation about product recall due to factory defect? You might want to ask for the contact info of their corporate legal and see if they want to handle it internally and rethink the price? Or you might not. You sell, how would your company handle something that could be a potentially dangerous defect?
A lot of times a company will job out this type of work. With the amount of rust seen, it looks like the wrong type of wire was used plus a bad weld.
That is not a easy weld to do because the welder must pass fast enough so not to cut through the tubing and slow on the plate to burn into the material. From the welds I have seen on tuna towers it takes 2 passes, one for welding a buildup to the tube and the next to join the buildup to the plate. Which takes time & money.
- Gerald Gordon
- Gerald Gordon
waternwaves
makes me wonder tho....
Seems the weld on the other end of the post (cabin top) would be made with the same wire as the foot........
An inspection of the top weld may show some interesting failure also.(eitherworkmanship or material) With that particular kind erosion.....it looks like a non-stainless wire might have been used.
