Central Vac on a Mac?
DLT
Post by DLT »
I got a cheapo black and yellow one from JC Penny outlet that could be used to inflate stuff... It was ~$20 IIRC...
craiglaforce
Post by craiglaforce »
I have thought about mounting the top part of a wet vac to the bathroom sink, and putting a valve on the drain hose. I never use the sink, and this would give the shop vac a place to sit all the time, and the water collected could be then drained out through the thru hull.
Actually, I think I saw a really big shop vac that had a water drain pump in the bottom of the reservoir. maybe that would be easier, just mount it in the back void and brink the hose forward when needed.
Bill at BOATS 4 SAIL
Sailboat: MacGregor 26D
If you had a DC central vac, and the wind died, I think you could reverse the wires, point the hose at the sails and you should still be able to sail.
DLT
Post by DLT »
I use it to fill my spinnaker!
I use it on the front of the main for suction...
Seriesly, a Dyson will never clog.....
ssichler
Post by ssichler »
I picked up a 1 gallon 12 volt vac that can be used as inflator/deflator from overton's - http://www.overtons.com/modperl/overton ... _num=26753
RandyMoon
Location: Rockwall, TX Lake Ray Hubbard 2005M #0690 L405 Tohatsu TLDI 90 (Rhapsody in Blue)
Post by RandyMoon »
I tried to follow Scott's advice but could not find a Ho' Med e' pot. So I went to Lowes and bought a nice 2.5 gallon dry/wet vac.
Thanks for the idea guys.
Scott
Post by Scott »
Much as I hate to resuresct such a silly thread.....................
Funny thing happened on my bike ride home from work.
I was stopped at an intersection waiting for the light to turn and off to my right was some telecom guys cleaning out a switch box. (hey engineers, do they still call them that) They were using a vacuum machine with a flex hose on the suction side and an open air exhaust on the other. The motor and pump couldnt have been more than 6x6x6.
Similar to this. Some of these were water OK and had a lift rating of 40". You could keep the bilges dry with that.
Sooooooo........ I got to thinking that this would fit nicely in the battery compartment and if you plumbed an inlet there and on the front wall at the front of the sole you wouldnt even need that much hose. The dirty/ exhaust side could then be plumbed under the aft berth and vented through a scupper on the inside vertical of the transom negating the need for bags or buckets????
Hmmmm, hah, huh, Hmmmmm? Thinks what do you????
ssichler
Post by ssichler »
ssichler wrote:I picked up a 1 gallon 12 volt vac that can be used as inflator/deflator from overton's - http://www.overtons.com/modperl/overton ... _num=26753
FYI looks like Big 5 has these 1 gallon 12 volt shopvacs on sale for $12. Very handy.
albion
Location: Medina Ohio 2007 Mac26M Suzuki 50hp Hull#M1494g607
DYSON ?
Post by albion »
Catigale wrote:I use it on the front of the main for suction...
Seriously, a Dyson will never clog.....
Only problem I have with Dyson was the guy who started the company with the help of friends, got rid of all the people that built up his factory in UK then fired them and shipped the work abroad.Oh & a friend of mine in England bought 2 of them, after the second one conked out she said never again.Went back to Hoover
Re: DYSON ?
Everyman wrote:Only problem I have with Dyson was the guy who started the company with the help of friends, got rid of all the people that built up his factory in UK then fired them and shipped the work abroad.
Wow. That sucks.
Sorry... couldn't resist. :D
Oh crap - a great product with a socially unconcious corporate...a real dilemma
I have a couple of Dysons and they have been bulletproof and work great
Divecoz
Re: DYSON ?
Post by Divecoz »
On a Grander scale here think . . . . . .NIKE!
Based at one time outside Portland Oregon . Paid decent wages was a thriving Company making 100's of millions of dollars on $100 gym shoe's
Moved to China laid off everyone in Oregon and raised the prices to (drum roll please) $150 for Air Jordons! No longer paying Americans a living wage.
I seriously fear that trend is in store for most North American businesses. Global competition is changing at a rate that is catching us all off guard. Very dangerous for national employment options.
You bet... we've lost a ton of good folks at our firm - their jobs are now being done by folks in Bangalore. Unfortunately, they are also being done badly.... **Sigh** .... Progress, of a sort.
