Where do I mount a 22lb Super Hooker on the 26M?
- richandlori
No, Im not talking about a lady of the evening, but a 22lb anchor. Yes, I know, I know, a 22lb is way oversized for the Mac, but one anchor slipping incident on an overnight trip with the admiral and kids would have effectively ended my overnighters on anchor, so I went big.
My problem is I cant find a good/decent/doable place to store the beast while under way. Right now I keep it sitting in the aft bunk, but that takes up room and is a PITA to move around. I cant keep it on the anchor roller, because it would interfere with the roller furler. I think it is too heavy to mount on the bow pulpit. It wont fit in the locker. It is driving me crazy. I was thinking about fabricating a mounting bracket on the port transom indentation on the M, opposite the ladder entry. At least there it would be out of the way and ready to deploy from the cockpit.
Any recommendations or thoughts? I like the anchor, but it is becoming the millstone around my neck(pun intended).
Rich
Rich
- craiglaforce
- richandlori
I have tried hanging it from the Bow Pulpit by one of those Square mounts, but the shaft (not sure of the exact nautical term) hit the rub-rail.
I do like the idea of raising the RF up to gain more clearance for my anchor roller and to help increase visibility. It may also help keep the Genoa (150%) from rubbing on the bow pulpit quite as much.
Can I get some additional explanation on how others have done this? I can see shortening the attachment point on the mast, but the bottom end has me thinking.....?
Thanks
Rich
Thanks
Rich
- Terry
Raising the headsail foot.
Catigale,
You have an
, Rich has an
Both boats use the same headsails but the M has a taller mast therefore a higher attachment point for the hounds where the forestay attaches. I use two hank on headsails, a jib, or Genoa and one day I was sighting up the mast and forestay and noticed I had room to hike the foresail up higher. I simply added a 6" SS extension plate to the attachment point at the bow and raised the foot of the sail 6" to clear the pulpit a bit more. I believe there is room to raise it 8" or maybe 10", not sure about 10 though. Rich may be able to do this mod without moving the hounds at the upper reach of the mast.
You have an
pvc
http://i5.photobucket.com/albums/y159/f ... 010001.jpg
looks like crp, but works ok...
I cut this down later, flush w/ rail... works for #13 danforth.
- craiglaforce
- richandlori
