A minor little mod the Admiral really likes...me, too
Herschel
Post by Herschel »
My '98 26X came with a barrel bolt on the head door. Don't know if it was OEM or the PO installed it. Either way, it has been a knuckle busting PITA over the years. With some outside temperatures it easily fit into the catch; other times of the year or even points of sail, it took a hammer to get the knob to move to the open position. Well, today I took it off and installed a rubber stretch clasp I found at WM. My Admiral is ecstatic. 8) Here is the old latch:
Now the new one in the locked position:
And the unlocked position:
Re: A minor little mod the Admiral really likes...me, too
:D Necessity is the mother of invention
Ray ~~_/)~~
Stickinthemud57
Post by Stickinthemud57 »
Good move. I had to file the bolt on mine down to make it operable. I will keep this mod in mind. Thanks for sharing!
Cool 8)
That,s a new way for stretching ur toilet time ! so r u now allowed to take 2 sailing Mags in there now :)
John.
The lock is on the outside. A mischievous Herschel could lock the admiral in😈. That could present a challenge to his counseling skillsπŸ˜€
Ray ~~_/)~~
NiceAft wrote: ↑Fri Feb 11, 2022 10:40 am John.
U got me good their ! :cry: :?
J :|
mac n cheese
Post by mac n cheese »
Clever latch...good job. My '98 :macx: was having issues with the original barrel bolt in which it was fiddly to try and latch/lock it. Investigation revealed the hinges were worn and sloppy. FYI if yours are worn and the door is sagging the hinge is Sea-Dog P/N 201954-1 easily sourced at
your local marine store....or here.
https://www.amazon.com/Sea-Dog-201954-1 ... s=201954-1
Specs here..
https://www.sea-dog.com/groups/343-flus ... aled-hinge
Herschel
Post by Herschel »
Ironically, I have pondered how a person could get out if accidentally trapped inside the 26X head. The barrel latches would be awfully hard to defeat from the inside, but this rubber one I think would be less of a problem. It has enough give to it that I think a person could get a finger out and release it. If armed with something sharp even cut it. Since my wife and I are septuagenarians, I don't expect we'll find ourselves in that fix, but you guys out there with younger children could foreseeably encounter an "accidentally" locked in younger sibling! :wink: but hopefully NOT!
OverEasy
Post by OverEasy »
Nice Mod! Like it!
Yup, that barrel bolt is a PITA!!! :x :x
Little tiny @#&*$% knob and a tight fit if anything flex’s or sags. Fooey!
Herschel
Post by Herschel »
First time in action for new latch. Admiral very pleased! 8)
OverEasy
Post by OverEasy »
TMI :| :|
Herschel
Post by Herschel »
OverEasy wrote: ↑Sun Feb 13, 2022 8:40 amTMI :| :|
Perhaps you are right, but just wanted folks to know that the "field test" went well. Don't want to post a mod that doesn't work as advertised. Latch held nicely during transit to the marina on an expressway trip of 25 miles and during a WOT run around the lake. And, of course, it was easy to open when needed. :)
OverEasy
Post by OverEasy »
Hi Herschel!
Important things first!!! No need for understatement at my age! :D :D
Leastaways in my book! :D :D
