Track sliding cam cleats
panda
Post by panda »
I would like to be able to control jib simply using track sliding cam cleats. Would these work? https://www.velasailingsupply.com/viada ... cam-cleat/
Or: https://www.garhauermarine.com/track-bl ... -cams.html
:macm: 26M 2008, New York
Re: Track sliding cam cleats
Panda,
Did you check Blue Water Yachts for a price check?
I use Bill's ez cleats for my genoa (2005 :macm: ), they look like what you are inquiring about.
panda
Post by panda »
Thanks Ray, yes just did. Looks like twice more expensive.
Your local says NYNY. Are you in the five boroughs, or Long Island, or north?
Gazmn is in Queens.
pitchpolehobie
Post by pitchpolehobie »
panda wrote: Fri May 28, 2021 12:00 pm I would like to be able to control jib simply using track sliding cam cleats. Would these work? https://www.velasailingsupply.com/viada ... cam-cleat/
Got a set from bwyachts, best sailing upgrade I think I've done
2002 MacGregor 26X: Remedium
Tohatsu 25HP
I use those cam cleats on my genoa. They work great.
for the small jib, these work great
http://shop.bwyachts.com/product-p/4601-1v3.htm
Spector
Location: Calgary AB, 98 26X 'Cenoté' 2002 Yamaha 60 HP
Post by Spector »
We have the garhauer. They work great. I run the line thru a turning block first.
Cenoté 1998 :macx:
Calgary AB
MYCBC member
pitchpolehobie
Spector wrote: Sat May 29, 2021 6:05 am We have the garhauer. They work great. I run the line thru a turning block first.
I've thought about using the turning block first, or even around the winch to lighten any load from gusts.
Tohatsu 25HP
Be Free
Post by Be Free »
+1 on the Spinlock rope clutch. Easy to lock and unlock from the rear of the cockpit.
2001 26X Simple Interest
Honda BF40D
DaveC426913
Post by DaveC426913 »
Russ wrote: Sat May 29, 2021 6:01 am I use those cam cleats on my genoa. They work great.
Yep. Best upgrade on my boat by far.
kurz
Post by kurz »
Yes best mod. Nand forget the winch...
DaveC426913
kurz wrote: Sun May 30, 2021 1:23 am Yes best mod. Nand forget the winch...
Explanation:
Two lines on the winch control one sheet.
The only way to stop (False) hauling the sheet is to haul on both lines (True,True).
:P
DaveC426913 wrote: Sun Jun 06, 2021 5:56 pm
Explanation:
:P
Sorry Dave, but I have no idea 🤷🏼‍♂️ of what you said :D
As Russ said, “ I use those cam cleats on my genoa. They work great. ”
DaveC426913
NiceAft wrote: Sun Jun 06, 2021 6:49 pm Sorry Dave, but I have no idea 🤷🏼‍♂️ of what you said :D
Sorry, nerd joke. Couldn't resist.
On Sun May 30, 2021 3:23 am, Kurz said "Nand winch."
A NAND gate is a logic gate that only outputs FALSE if both inputs are TRUE.
So, a "NAND winch" would only stop winching if both lines on it were hauled-on.
I will take your word for it; now I'm going to take two aspirin for my headache from trying to figure out what a "gate" is :? :D
