Track sliding cam cleats
- panda
I would like to be able to control jib simply using track sliding cam cleats. Would these work? https://www.velasailingsupply.com/viada ... cam-cleat/
Or: https://www.garhauermarine.com/track-bl ... -cams.html
Re: Track sliding cam cleats
Panda,
Did you check Blue Water Yachts for a price check?
I use Bill's ez cleats for my genoa (2005
), they look like what you are inquiring about.
- panda
Thanks Ray, yes just did. Looks like twice more expensive.
Your local says NYNY. Are you in the five boroughs, or Long Island, or north?
Gazmn is in Queens.
Gazmn is in Queens.
- pitchpolehobie
Got a set from bwyachts, best sailing upgrade I think I've donepanda wrote: ↑Fri May 28, 2021 12:00 pm I would like to be able to control jib simply using track sliding cam cleats. Would these work? https://www.velasailingsupply.com/viada ... cam-cleat/
2002 MacGregor 26X: Remedium
Tohatsu 25HP
Tohatsu 25HP
I use those cam cleats on my genoa. They work great.
for the small jib, these work great
http://shop.bwyachts.com/product-p/4601-1v3.htm
- Spector
- Location: Calgary AB, 98 26X 'Cenoté' 2002 Yamaha 60 HP
- pitchpolehobie
I've thought about using the turning block first, or even around the winch to lighten any load from gusts.
Tohatsu 25HP
Tohatsu 25HP
- Be Free
+1 on the Spinlock rope clutch. Easy to lock and unlock from the rear of the cockpit.
DaveC426913
DaveC426913
Explanation:
Two lines on the winch control one sheet.
The only way to stop (False) hauling the sheet is to haul on both lines (True,True).
Sorry Dave, but I have no ideaDaveC426913 wrote: ↑Sun Jun 06, 2021 5:56 pmExplanation:
As Russ said, “ I use those cam cleats on my genoa. They work great. ”
DaveC426913
Sorry, nerd joke. Couldn't resist.
On Sun May 30, 2021 3:23 am, Kurz said "Nand winch."
A NAND gate is a logic gate that only outputs FALSE if both inputs are TRUE.
So, a "NAND winch" would only stop winching if both lines on it were hauled-on.
DaveC426913 said:
I will take your word for it; now I'm going to take two aspirin for my headache from trying to figure out what a "gate" isA NAND gate is a logic gate that only outputs FALSE if both inputs are TRUE.
