I removed the sink and most of the floor so that I can stand directly on the hull. I added flooring where the sink is now and mounted my potty there.
This gives enough head room to actually put clothes back on while standing on the hull, (with head bent over, I am 5'10")
NOTE: The ballast tank is partially under the bathroom, so if you follow me, do not cut too deep near the door.
Given the angle to the virt. wall to the right of the sink, I think this gives the max room possible.
After painting, it does not look too bad and makes an almost useless space to almost OK.
Picts:
NOTE: Guess I still need to clean up my edges, but you get the idea.
I also opened up the V-birth in an attempt to actually sleep there with a real mattress. Took out the floatation and the anchor locker.
