Pop top cabin connection to mast
Orkia
Post by Orkia »
I have a 26 S and I am trying to figure out the connection of the pop top cabin to the mast. I understand that there is a sliding bracket in the mast track that is supposed to connect to the mast side hole in the pop top with a hook connection. I am not sure I get exactly how this works. Does anyone have a picture of how they do this?
Maraquita
Sailboat: MacGregor 26D
Re: Pop top cabin connection to mast
Post by Maraquita »
I'm afraid I don't have a picture, my boat is still covered for winter with the mast down, but on my 26D, the connection is a stainless piece about 3 inches long, with a joggle in the top and a lower half shaped so as to slide in the sail lug slot on the mast. It normally sits down on the deck at the base of the mast. When you wish to secure the pop top, you hold the pop top against the back of the mast and slide the piece up to where joggle slides aft of the pop top edge and secures it in place. There is a thumb screw threaded through the support that you can screw into the hole in the pop top so that the support will not slide out of position if you accidentally bump the pop top forward. If nobody else can come up with a photo, I will be uncovering my boat this weekend and can get one then.
HH
Orkia
Post by Orkia »
OK that makes sense. I got it.
go to resources above look @ page #18 on the Mac26S manual there is a pic there :wink:
Mac26S-95
Post by Mac26S-95 »
If it's still unclear, let me know. My 26S is in the water now and I can get more pictures to share. :)
Mac26S-95 wrote:My 26S is in the water now and I can get more pictures to share. :)
But is your dock in (or under) the water, too? :o
Mac26S-95
Post by Mac26S-95 »
:D My dock is floating (like yours), however there is a substantial puddle to walk through to get to my dock. On the bright side, the lake has come down a couple inches in that last few days and is forecast to continue coming down. 8)
Perfect day to sail, Tom - south wind and the lake is flat. I'll be out there in an hour or two. Stupid house chores first. :?
