I'm sure most of you are suffering from poor conntectivity from your trailer connectors. Those cheap 5 pin connectors rust and are useless after maybe 2 or 3 months of use. Well I decided to do something about it and I just discovered ezconnectors!
I ordered the S7-05 female socket (part number S7-05) and also the trailer side hookup S7-07-6 = $136 after shipping and handling
You will also need the B-S7-61 mounting brack and a mounting bracket on the trailer side (B-S7-63)
I also ordered an adapter so I can still tow old style 5 pin trailers. P-R7-55.
Over all very impressed with the setup. It uses double o-ring seals to prevent water from touching the contacts while submerged and also in storage. It also uses magnets to hold the connection while trailoring. I swear this is the LAST trailer connector you'll buy unless you buy a new vehicle.
Trailer connectors
andyman2000
Re: Trailer connectors
My 5 pin cheep connector is still working after 5+ years? I do keep it coated with Dow Corning DC4 tho.
- RobertB
I spray metal and connectors with BoeShield. Invented for Navy jets, I guess I can use it too. Available at WM and other outlets.
I also coat just about everything under the hood of my car also to prevent corrosion.
- cptron
My cheap connector has been working for 4+ years now and I have sprayed nothing on it but spit when I plug them together.
- mastreb
I rewire the trailer stem to stern every two years using off-the-shelf automotive parts store trailer light kits and tie straps for about $50. Faster and cheaper than troubleshooting the invariable corrosion issues, and there's zero point in doing anything expensive thats just going to corrode anyway. Cut everything off with tie straps, re-wire and tie-strap the new stuff down, wire on the new connector (7-pin for me), and done. Takes all of ten minutes when the boat's off the trailer.
andyman2000
guess I got too much money then. I do like the fact that the connectors are water proof and my vehicle side won't suffer any corrosion. I'm also super lazy so I doubt I will spray T9 very often. However thanks for the advice about the T9. I ordered some just in case. Just glad to see there are options are available and I thought I'd pass it along on this forum. If I knew about this earlier I would have bought it a long time ago.
I love this stuff
Got the tip from Divcoz and I use it anywhere corrosion or connectors are outside. Even use it indoors sometimes.
Fresh water guys wonder what this thread upis about.
Salt water, feel the pain and the sting of salt in our electrical wounds
