Worst part about getting a different boat ...
Azzarac
Re: Worst part about getting a different boat ...
Post by Azzarac »
That would be a monkey's fist however that is simply a knot.
Post by BOAT »
Azzarac wrote:That would be a monkey's fist however that is simply a knot.
No I remember now - it's called a "slungshot" - my dad hit me with one once - the knot is called a "monkeys paw" unless your younger - then it's a fist. Monkeys were not classified as primates until much later thus to the old folks they had 'paws' not a fist.
The "monkey fist" is after my time.
BOAT wrote:Don't forget the soap on a rope...
Doesn't count.
Remember, my challenge was for "singular nautical 'ropes' that are made of rope but are not called either a rope, a sheet or a line", and by both name and definition 'soap on a rope' is indeed called a 'rope'.
As to the thrown rope, that ball on the end is called a "Monkey's Fist" and is, as previously noted, just a knot and not an actual free line.
Post by BOAT »
Okay, no soap ropes. And there is probably no point at bringing up any of the lines on a square rig.
Anyone say 'hawser' yet?
Ixneigh
Post by Ixneigh »
On the old ships, Once they got the anchor up, they had to cat it. I had to make a special line to lower down and grab one of the anchor flukes to be able to raise the fluke end of the anchor into to the chatting position on my boat.
That line has a loop on the end that I lower down and slip over one the the flukes. It nooses closed behind the palm of the anchor and allows me to hang the fluke end off the bow rail. The anchor then gets further secured with another lashing. I placed a cleat on the bow rail just for this operation. I've been calling that line the "snivelgrapper" since you have to sort of snivel it down there over the arm of the anchor which can be tricky if it's swinging around.
They had a tackle of some sort on the old ships to do this operation with. Maybe Boat can inform us.
Since the challenge was not for made up stuff of course, my suggestion is the Topping Lift.
This is neither a rope or a line. It's just it.
Also, if it become line as soon as it comes aboard, then why is the line stored in a rope locker??
Ix
Post by K9Kampers »
A line that sailors use often...in a bar: You come here often?! :P
Tomfoolery wrote:Anyone say 'hawser' yet?
Nuts. I see the answers were given above. And hawser was in there. :|
Credit given for Hawser, tom. Since you left NYC your word is good here....
:D
marcopolo173
Post by marcopolo173 »
What about the shrouds and stays?
marcopolo173 wrote:What about the shrouds and stays?
Shrouds and stays are not made of rope (anymore).
RobertB
Post by RobertB »
My baby stays are Dynema - looks like a woven fiber, heavier than yarn or string :)
I think Robert has a case here...or at least a line on one.
vizwhiz
Post by vizwhiz »
Was reading an article in Sail (IIRC) that was talking about the trend to return to rope shrouds/stays away from cable and wire and rod...kinda "back to the roots" idea. Interesting.
Catigale wrote:Credit given for Hawser, tom. Since you left NYC your word is good here....
:D
:D
:D I'll take it. :D :D
