I have to agree on all points with Victor.
The wedge is a must. I can definitely say so after going with the Suzuki 100hp/1.950cc and installing a wedge.
I didn’t have a wedge with the previous Suzuki 70hp/1.300cc and in hindsight I believe I should have done so.
Look at it this way – if you don’t have the wedge you cannot tilt the engine further back if you need to. If you do have the wedge you can always tilt a little forward if you feel the angle is too far back.
I would add the following observation:
When powering high speed – without ballast – the bow does have a tendency to nose up so the motor is tilted all the way down. You can always shift loose items belowdecks to the v-berth forward if you want to bring the nose down a little further. This is what I do. With the Suzuki 100 the more I push the throttle, the faster I go once on a plane, the faster I go the bow tends to rise less.
The admiral and our daughter actually enjoy lying on the two settees (M 2004 model) on either side when high speed powering and not being in the cockpit, so this brings their weight not only more forward but further down well. When they go belowdecks, you immediately feel/see how the boat’s behavior changes (for the better).
Permanent weight in the bow is no good because, when you go into sailing mode – ballast full – The boat becomes a little bow heavy and then you need to shift weight aft to the double berth under the cockpit. This is where the extra weight of my big engine actually becomes a positive feature.
Victor,
having solved all the powering issues of our Mac M, I, too, am now focused on upgrading the stock sails in the near future.
Happy power sailing,
Octaman
