Ballast Valve Handle
- Compromise
Anyone have a solution to the ballast valve handle replacement? Mine leterally snapped when tryint to empty because of barnacles preventing me from pullig it all the way up!
My T handle is now a thing of the past! Any solutions without getting out a welding gun to it?
Thanks
Thanks
ballast handle strong upgrade
I drilled and tapped a hold for the ballast valve stem in a 316 stainless steel rod about 4 inches long. Thread that on the valve and the handle breaking is no longer a problem.
There might be a stainless hardware item that has the correct threaded hole already. IIRC the 1999 Mac26X ballast valve has a 1/4 -20 thread. The valve is an RV toilet valve, maybe the RV world has a sturdy handle.
Hope that helps.
Hope that helps.
Phillip
- Location: Sunshine Coast Australia 2000 26X Tohatsu 50hp
I had exactly this problem, and asked a similar question.
For all the mucking around trying to repair it, (and it is not going to be a long term solution) I learnt that the complete valve unit is not common to the marine world at all, but it is a sewer fitting.
It is called a Sliding Gate Valve.
Trout told me "you can buy a replacement at any RV store.
Measure your size and ask for the gray or black water (sewer) covers".
I found one at my irrigation shop, identical manufacturer, just that the opening is 90mm here, yours is 4".
Now if you undo the 4 bolts that hold your it to the boat, the outside cover will come off...make sure you don't loose the big O ring/washer.
Buy a new one, split it in half, and screw the half you need on the boat into place.....better use silicon too of course.
Job done....it will take 5 mins at the most.
The other day I was at an open-air event, and bxggar me, there was a long row of portable dunnies, and they all had this sliding gate valve on the back.
Phillip
Phillip
- Wind Chime
I added a cable control that threads onto the gate valve, leads thru the aft bulkhead, up into the pedestal, with a T-handle in there. So now the opening or closing is pretty simple, but the installation was not.
There are many other ways to skin this cat, but the simplest solution I've ever seen is one described right here in the early days. Use the boathook.
- David Mellon
- tangentair
- John Christian
- Location: 2007 26M "Pamela Jean" White Hull#1862, Suzkuki DF 70, Brest Bay Marina, Lake Erie
