Ballast Valve Handle
Compromise
Post by Compromise »
Anyone have a solution to the ballast valve handle replacement? Mine leterally snapped when tryint to empty because of barnacles preventing me from pullig it all the way up!
My T handle is now a thing of the past! Any solutions without getting out a welding gun to it?
Thanks
Post by Frank C »
Easy solution. Home Depot's hardware aisle has a bank of special drawers for unique hardware. Among our 'custom boat parts' that you'll find there:
  • Plastic handles (of various styles & thread counts);
    Plastic liner plugs (some stores);
    Expanding ballast vent plug.
Robert
ballast handle strong upgrade
Post by Robert »
I drilled and tapped a hold for the ballast valve stem in a 316 stainless steel rod about 4 inches long. Thread that on the valve and the handle breaking is no longer a problem.
There might be a stainless hardware item that has the correct threaded hole already. IIRC the 1999 Mac26X ballast valve has a 1/4 -20 thread. The valve is an RV toilet valve, maybe the RV world has a sturdy handle.
Hope that helps.
Phillip
Location: Sunshine Coast Australia 2000 26X Tohatsu 50hp
Post by Phillip »
I had exactly this problem, and asked a similar question.
For all the mucking around trying to repair it, (and it is not going to be a long term solution) I learnt that the complete valve unit is not common to the marine world at all, but it is a sewer fitting.
It is called a Sliding Gate Valve.
Trout told me "you can buy a replacement at any RV store.
Measure your size and ask for the gray or black water (sewer) covers".
I found one at my irrigation shop, identical manufacturer, just that the opening is 90mm here, yours is 4".
Now if you undo the 4 bolts that hold your it to the boat, the outside cover will come off...make sure you don't loose the big O ring/washer.
Buy a new one, split it in half, and screw the half you need on the boat into place.....better use silicon too of course.
Job done....it will take 5 mins at the most.
The other day I was at an open-air event, and bxggar me, there was a long row of portable dunnies, and they all had this sliding gate valve on the back.
Phillip
Wind Chime
Post by Wind Chime »
QUESTION:
I always find it such a pain to have to lean way over the transom to open and close the ballast valve. Even lost my hat once.
Any ideas on extentions for this valve handle?
Thanks!
Post by Frank C »
I added a cable control that threads onto the gate valve, leads thru the aft bulkhead, up into the pedestal, with a T-handle in there. So now the opening or closing is pretty simple, but the installation was not.
There are many other ways to skin this cat, but the simplest solution I've ever seen is one described right here in the early days. Use the boathook. :|
David Mellon
Post by David Mellon »
I remembered someone elses mod and dug up a copy. As I remember the blue handle is from a Waste Marine manual bilge pump:
The Waste Marine pump the handle came from is here:
As I remember there was some threading to do but I forget the details.
tangentair
Post by tangentair »
Is that first picture right? and the valve is on the starboard (right side) or is the picture flipped? My valve etc is on the port side. :?: :?:
c130king
Post by c130king »
I think that is an :macx: .
40Toes
Location: St. John's, Newfoundland, Ontario 28 - Formerly 2000 26X
Post by 40Toes »
tangentair wrote:Is that first picture right? and the valve is on the starboard (right side) or is the picture flipped? My valve etc is on the port side. :?: :?:
On the Stbd side of my 2000X.
bubba
Post by bubba »
A new valve is around $30.00 I had to replace mine when the threads on the valve rusted off and did not empty once when I pulled out.
John Christian
Location: 2007 26M "Pamela Jean" White Hull#1862, Suzkuki DF 70, Brest Bay Marina, Lake Erie
Post by John Christian »
Boat Hook is made for the job! If you mount it on your Mast support it's always available for the job.
JC
Scott
Post by Scott »
I just drilled a 2" x 1/2" piece of stainless and put 2 jamb nuts on it (1 self locking and presto. perm gate handle.
