This needs to be every Mac owners first modification
MARK PASSMORE
Post by MARK PASSMORE »
As hard as it is to get a Mac on the trailer in a heavy currant or any kind of cross wind. Not to mention how dangerous loading any boat can be. A few extra guide post should be the first mod on your list.
Don’t make the same mistake that I made by waiting until your gel coat is scratched.
For around $60.00 to $70.00 dollars and a few hours work you can have taller guide post. That will allow you to put the trailer deeper in the water. Which allows you to keep the dagger board down a few inches until you are a lot closer to the trailer before pulling it up completely. Also with the second set of guide post the bow of the boat doesn’t swing sideways once you get half way up on the trailer. Now I look like a pro at the ramp.
Beepa Nick
Location: Port Byron, IL (Motor on the Mississippi; sail on Little Bay de Noc, Green Bay, Lake Michigan)
First Mod
Post by Beepa Nick »
8) :idea: I agree, Mark. For my first modification I made the existing guides "taller" by simply slipping 1.5 inch PVC over them. Adding a second set of guides will make it a lot better. I also have ended up "crosswise" the trailer in a strong river current or crosswind...to the detriment of the gel coat and prop. Thanks for a great idea! :macm:
Jack Sparrow
Location: Cairns, Australia 2007 M 50 Yamaha Run to Paradise
Post by Jack Sparrow »
I havn't done this one yet
Jack Sparrow
pokerrick1
Sailboat: Venture 23
Left Coast
Post by pokerrick1 »
I solved this problem by keeping my Mac in the water 100% of the time and using it 5 days a week :P Of course, I have migrated to the Left Coast :P (again)
Rick :) :macm:
Boblee
Post by Boblee »
We used the extra guides from the dealer but like the idea of extending them higher, can think of plenty of times where it would have been more than gelcoat scratched.
Actually this is the only option that our dealer actually "Recommends" on his list.
Of course being a Smart A I didn't take any notice until almost making a mess of the boat, sometimes we should take advice from people who should know.
pokerrick1
Ha
Ha!! You think you're a smart A :P
Rick :) :macm:
Mistral
Location: Patterson Lakes, Melbourne, VIC., Australia 2005 26M "Indigo Blue" 50HP E-Tec
Post by Mistral »
That'll be my next thing on the list. The boat nearly swung sideways this morning when launching.
MARK PASSMORE
a few more photos of the parts needed
pxk3
Post by pxk3 »
Can you provide any parts numbers for the hardware you used to make the 2nd set of guide posts :?:
MARK PASSMORE
I was trying to find my receipt so that I could tell everyone the name of the parts but I’ve misplaced it. The pipe is simple conduit I think it is galvanized so it will not hold up to salt water as long as alloy or stainless but it is cheap enough that when it starts to rust just replace it. :?
The key is to buy the elbow a little bit bigger than the pipe so that the pipe will slip into the elbow. Then PVC fits over the galvanized pipe.
I bought 2 ten foot pipes and cut them in half giving me 4 five footers. I cant remember what the brackets were called it seems like leg brackets or something. Just print the picture and take it to the hardware store and ask for something similar. :|
I found that even after I tightened down the large bolt to hold the elbow it was still a bit loose so I drilled two cross holes and put two stainless bolts through sideways. That did the trick it is very sturdy now.
Remember to use oil with the drilling and it is very easy. :)
Boblee
Post by Boblee »
Rick I know I am a smart A as everyone tells me so, my son even tells me he is going to put a urinal on my headstone so everyone who couldn't get a word in while I was alive can p1ss on my head. :D
I was born this way and come from a long line of smart a's must be the Scot blood as the french/pommie side wouldn't cause it :D :D
puggsy
FIRST MOD
Post by puggsy »
To solve the side drift problem, I ran a line down each side from the rear existing staunchion on the trailer to the tip if the pipe "V". To fix the line at the "V" I added a shackle to the tip of each arm. Then using swimming pool spaghetti, the multi coloured floating stuff with the hollow centre, ran those side lines through the spag. centre for the whole length. As well as the pipe arms of the "V". Then fixed them as tight as I could get them. They form two straight lines from the staunchions to the "V", actually narrower than the :macm: . As the :macm: goes on to or in to the trailer, there is no scratching due to the spag. [ very soft] and the lines just expand and stretch sideways as the :macm: goes on...She can't go nowhere!. No stretch line is best, but I used a 2 cheap 9 metre lengths that cost $2 a pack. The spag, was 8 lengths X $2 = $16. If the :macm: is pushed sideways at all, the rope just gets tighter and holds her...
puggsy 06 :macm:
Post by Kelly Hanson East »
for 40 use you could fab this all out of PVC and just STD fittings to make the right angle turns
Attach by lashing or ss hangers
Drill holes in bottom to drain
No corrosion to worry about.
Boblee
Post by Boblee »
Thats not a bad idea Puggsy as you say it can't go anywhere, not sure what you mean by the pool spaghetti though.
Oskar 26M
Post by Oskar 26M »
I like puggys pool spaghetti idea.
On the original thread, rollers on the guide posts probably reduce the risk of scratching when battling a crosswind during retrieval
Oskar's trailer is still in the workshop being upgraded, but here is a pic of what its rollers look like:
