Research: Discussions on lubricant, Teflon washer replacement and other methods were found in this and other forums. Talking with other
Objective: Find a way to keep the mast rotating as designed without the need to go up on top every time it hangs up.
Method and equipment: Lolling on the rear deck one day, contemplating the spare parts in the tool box - VOILA! - Two lengths of 5/16 braided line secured to the vang shackle at the flange on the mast base running 90 deg through the extra blocks on the jib rails ('Skye' has a Genoa, no jib), then tied off on the stanchions just ahead of the cockpit.
Verification: Sea trials* this past week verified the premise - light tug on the line helps the mast rotate to the desired position. No goo, no muss no fuss.
whudja tink?
cheers,
Rick
* note: the term "sea trials" is used colloquially, simply because "lake trials" just doesn't sound right.
