Rotating mast - speed gain?
Paul S
On our 04 M I sometimes pin the mast not to rotate (when using the boom brake). Our outing this past weekend, I forgot and left it pinned until later (just before we pulled out).
It seemed like the boat went noticably faster after I removed the pin and let it rotate .. about 1 kt faster. Unless it was just a coincedence, and inconsistant sailing....the rotating mast does appear to have some value, other than just cool marketing material.
- baldbaby2000
- captin5317
I to have forgoten to remove the pin on ocassions, wondering what seems to not be right. As soon as the pin is removed and the rotating mast starts to perform a noticable improvement in handling and performance. Have yet to check actual knot increase. Sounds like a project next time out. 13 times on the water in 4 weeks <SMILE> and lovin it!!!!
Bruce
Bruce
Paul S
It doesn't come with one (It should). I just drilled a hole in the base if the mast and continued into the plate under the mast and got a detent hitch pin http://www.wilsonmfgco.com/hitchpins/detentpins.htm at the base of the mast. Also works well keeping the mast centered when trailering..shehzad wrote:I am sailing Mac M 2005 model for the last several months but never saw the pin, you had been talking about.
Where exactly is it situated. I have noticed that the mast only rotates in heavy winds. It require lot of power, if I try to move it by hand.
Paul S
here is a shot with the mast pinned...Got to use the boom brake a couple times on Sunday. Pretty cool..had it set too loose at first..and the boom came across a hair faster than I was expecting..but didn't bang like it used to without the brake. Got it set to where it just came over at a controllable, less scary, pace.
But here is the mast not being rotated:
Paul S
Something is wrong then, it shouldnt be that tight. Your standing rigging could be too tight...or your forstay/roller may not be right.shehzad wrote: I have noticed that the mast only rotates in heavy winds. It require lot of power, if I try to move it by hand.
Check to make sure the base plate moved easily when the mast is not up..shouldnt be too tight.
Unless our boat is not set right..the mast rotates pretty easily
Paul
- baldbaby2000
- aya16
When tacking pull the main sail in tight before you go across the wind, This will avoid any sudden hard slams when the boom comes over. Do the same with the jib sheets then only a minor adjustment of both sheets is needed after the tack. As you make your turn hard over into the wind then catch or turn the wheel hard over to stabalize the course. Then let the sails out till they luff some, then slightly pull them in for shape.
Having the boom fly across at warp speed will not hit anyone that is sitting but its hard on the hardware. Plus it looks better when done right.
for anyone that might want to know.
all misspelled words are intentional its called Macbonics.
