Yesterday I replaced both control cables. I dropped the lower unit to check the water pump impeller. I removed the internal flywheel cover and checked the Honda BF50A belt and put in a new thermostat. I changed oil and filter. I put in new spark plugs.
During all that, especially taking apart the control head, I threw all the screws, washers, pins, bolts, nuts, etc. into a small box. Also, I completely removed the control head even though I did not need to. (My bad)
All went well, but I took no pictures during my work. After all the work was done I found a pair of stainless steel screws left over . I have tried to identify them and so far have no idea where they go.
Any help would be appreciated.
Thanks
Opie
