Window leak
Bobglas
Window leak
Post by Bobglas »
Starboard window over table leaking. Looks like tiny screws holding it in. Black silicone to seal? Anybody w experience? :macm:
March
Re: Window leak
Post by March »
The topic has been discussed--do a little search. I had suggested an automobile related product meant to seal the windshields, but was gently, politely, and uncompromisingly rebuffed. The professional solution is to remove the window and redo the seals
My window no longer leaks
kenfyoozed
Sailboat: MacGregor 26D
Re: Window leak
Post by kenfyoozed »
Use Dow 795 and 3M VHB tape. VHB tape to help hold along with the screws and provides a small gap for the sealant to fill. Boat works today on youtube has a great video on this.
Re: Window leak
Check out this in the Mods section. It's for a replacement, but it should give you the info you need for a repair if you don't wish to replace.
https://macgregorsailors.com/mods/index ... tem&id=806
