Hole in bottom end of rudder
RichardW
Sailboat: MacGregor 25
Post by RichardW »
I am in the process of refinishing my rudder on my Mac 25. The PO had applied antifouling paint on the rudder which I removed, which revealed a 1/4" drilled hole on the bottom end, on the side of the rudder. Is this for water drainage, as it seems that the rudder is hollow. Should I leave it open or plug it up?
Hamin' X
Re: Hole in bottom end of rudder
Post by Hamin' X »
Not sure about the 25, but my 26X had hollow rudders with a hole. The hole allows water in to keep the rudder from floating, as well as allow for drainage.
Since I am not familiar with that class, I can only use my :macm: as an example. There is a drainage hole in the :macm: rudder.
On the 25, is there a line to raise the rudder from the water? If yes, then a drainage hole is probably a good guess.
I don’t know why painting over the hole is desirable. If there is a hole for water access and egress, there should be another hole for air to do the same.
RichardW
Post by RichardW »
Thanks for your input. I will leave the hole open.
RichardW wrote: Thu Mar 05, 2020 1:10 pm Thanks for your input. I will leave the hole open.
How about a photo?
