First up, a trailer swap. My X is a 2001 sitting on the original trailer. Both wheels/hubs have failed and are no longer attached. And the axle may be broken. Not sure.
A few years ago I bought a Venture trailer for her but couldn’t afford to do anything with it after that. The past couple of days I’ve reset it to hopefully fit the Mac:
I used measurements from the original trailer as well as info found searching this forum to set the trailer up. The bow roller/winch is the same height as the original factory trailer. Length from trailer bowroller to the stern end of the bunks is 22.5 feet.
Eventually I’ll add guide ons of some sort on the sides for loading. And some sort of support to rest the swing keel on.
The bunks are not at their final heights or widths yet. Setting that as close as I can to fit the boat today. Just waiting on the dew to dry before I go crawling on the ground.
Couple of questions for you gurus: First, there are only 2 cross members supporting the new long bunks. I’ve seen similar setups with two but also three. Three seems safer. Do you think I need the third? If so, do you think it would be ok with two just sitting in the yard for a couple months? I’m already over budget on the trailer project but I need to get the trailers swapped to get the HOA off my back.
Second, The big part of this project is getting the boat moved over. Current plan is to jack the boat up using a mix of two 4x10 beams and 4x4’s as needed and maybe support the stern with a couple stacks of old tires for insurance. Then cut the old trailer out section by section, sliding the new trailer in as we go. Sound feasible? Any advice or do’s or don’t’s?
I’ll post updates if anyone is interested. And I appreciate any and all advice.
