retrofit mast
1st son of a sailor
- sailboatmike
Re: retrofit mast
Im not really sure what that would achieve, you would need to replace the main as the M main is slightly bigger, change the positions of the chain plates and I'm not sure you would get bang for your buck performance wise.1st son of a sailor wrote:Has anyone considered or completed the retrofit of the M rotating mast to a 26X?
Seems a very expensive exercise to achieve very little, IMHO you would be better spending your money on good sails for the X and maybe changing the rudders and centerboard over for performance versions. All in all there isn't a huge amount of sailing performance difference between the X and the M
- kadet
Re: retrofit mast
What sailboatmike said,
I pin my
mast for transport and often forget to unscrew the pin and sail all day with the mast pinned and unable to rotate, honestly never notice the difference
I pin my
Re: retrofit mast
The
mast is 2' longer and a heavier/thicker spar.
The mainsail area of the
is listed as 130sqft &
as 170sqft. I remember Roger hyping the increased sailing speed of the
over the
with only the main and no jib when it first came out. I wonder how much is due to the rotating mast, and how much is just 25%-30%more sail area on a similar boat with no jib
1st son of a sailor
Re: retrofit mast
Thanks for the quick replies...i was just toying with the idea but this love affair with boats and water has cost us all plenty.
i can spend my allowance in better ways i suppose.............radar arch and more electronics maybe???????
thanks again
thanks again
vizwhiz
Re: retrofit mast
Someone has done the conversion to rotating mast on a D boat a few years back. They used the M hardware with their D mast, and reported very good results, particularly in light winds. At very low wind speed, they were able to make headway, where they hadn’t in the past with the fixed mast. Anyway, you might look into swapping some hardware out on your X and see if it will work.
- kurz
Re: retrofit mast
How you pin thekadet wrote:What sailboatmike said,
I pin mymast for transport and often forget to unscrew the pin and sail all day with the mast pinned and unable to rotate, honestly never notice the difference
Do you have a photo?
thanks
- Ixneigh
Re: retrofit mast
After sailing the rotating mast, I would use the concept on any small boat. Only way I'd be without it is an unstayed wing sail or modified lug rig. It is extra handy when sailing with no board down.
- kadet
Re: retrofit mast
Drill a hole in the mast base plate below vang mount hole, tap it then put in a wing bolt .kurz wrote:How you pin thekadet wrote:What sailboatmike said,
Mast?
thanks
I use this to fix the mast for trailering so it doesn't rotate and damage my aerodynamic alloy furler
https://photos.app.goo.gl/p46SvQy0FhkXgqLa2
