I wanted to share this Hard Dodger mod with the forum since I am sure many of you have searched for a good dodger solution for the Mac. I too searched all over for a dodger that would fit the bill but was never really satisfied with what was out there so I built my own hard dodger out of marine ply and epoxy. I am really happy with how it turned out and the protection, visibility, and extra shaded headroom it provides.
Built this onsite with the boat in its slip, first framing it out, then cutting the individual pieces, routing the window inlays, cutting the sliding hatch pass-thru, epoxying and clamping everything together, then took it home to the garage for sanding, epoxy sealing, more sanding, painting, and stainless hardware installs.
Front window on stainless hinges lets air through to the cockpit when desired, otherwise this dodger cuts down on wind and spray dramatically and allows much more headroom standing at the galley and at the base of the companionway steps. Sliding hatch passes directly through the bottom frame but the gap is minimal so everything stays dry. Best upgrade I have done to the boat - and I have done many...
I have a bristol 2003 26x (original owner) that has been heavily upgraded for sale if you guys know anyone interested:
https://losangeles.craigslist.org/wst/b ... 85105.html
