Water ballast tank cleaning.
macsandy
Post by macsandy »
Got the boat out of the water and emptied the ballast.
Putting it politely, the smell was "offensive".
Any recommendations for cleaning and preventing future smells!
Gazmn
Re: Water ballast tank cleaning.
Post by Gazmn »
A Pt of bleach or pool chlorine tabs, while in the water & ballast filled. For winter layup I got nothing. Smell should go away - Unless something died in there :?
Gazmn wrote:A Pt of bleach or pool chlorine tabs, while in the water & ballast filled. For winter layup I got nothing. Smell should go away - Unless something died in there :?
+1
How about doing this in reverse. Dump some bleach in there and fill the ballast with a hose via vent. Let it sit for a day and drain it.
If you can leave it open, once it dries out the smell will likely stop. However that might take some time.
cptron
Post by cptron »
++1
We do about the same except we use the pool shock crystals for pools. I think we use it a little heavy and use about 1/4 bottle per ballast tank fill. Cleared out the smell from having salt water living in it for several months and then emptying it. Just 1 treatment and smell has gone and not returned since we use in every fill of the ballast.
