Steel Trailer Drawing
Neo
Post by Neo »
Hi All,
Does anyone have any drawing of the original Steel Frame 26M Mac Trailer they could share with me?
Many thanks for your help.
Neo
Neo
Re: Steel Trailer Drawing
Post by Neo »
I ended up doing this myself.... This is for my own 2005 Trailer
I measured the trailer and drew this on PowerPoint (took a LONG time!!). It's not brilliant but hopefully understandable?... It's not drawn to scale and it's not 100% accurate, but pretty close....Measurements are in millimeters.
I used the rubber V-Block as a main reference point. There are 5 measurements marked in Red. IMO these are critical points.
I may update this if I discover any errors ... Let me know what you think?
All the best.
Neo
I don't see any elevations for the bunks. When I sketched the bunk arrangement for my OEM :macx: trailer (for future reference), the two large bunks were at the same elevation at the apex, but the little one up front was higher. That's important, as the boat sits on all three bunks at once.
Also, is that the OEM aluminium :macm: trailer? I thought one of the big bunks was actually on the axle.
Neo
Post by Neo »
Hi Tom,
Yes it's a 2D view at the moment. But I'll try and measure up the 3rd dimension this week.
It's a steel trailer with just one small bow bunk, one big middle bunk and two bunk pads (port and starboard) at the back.
The lack of support often worries me, but it has the 2005 Mac compliance plate, so unless that's counterfeit it's the original trailer. So it's done quite well over the years.
BTW, after doing a Mac Bump I often find the bow sitting 1 or 2 mm above the bow bunk and resting on the V-block instead.... So I'm wondering if I should be doing something like raising the bow bunk?
All the best.
Neo
sailboatmike
Post by sailboatmike »
Thanks for taking the time to do that Neo, a great resource for the forum for future reference
Neo
Post by Neo »
Thanks Mike,
I believe we need to support each other if we want to sail together :) ... And I wouldn't wish an 11 or 12 thousand dollar bill on any Macgregor owner.... I still need to crack that problem .... but I'm working on it :D
All the best.
Neo
sailboatmike
I see the problem being once you go over 2000Kg GMV, the price just goes silly after that.
Torque axle suspension may be the way to go, less weight because there are no springs, hangers etc so more load available for the boat even a tandem.
I will have to bite the bullet and give some of the Australian suppliers a call in regard to pricing, but I fear that the price will be nasty
Neo
Post by Neo »
Good luck with that Mike. :)
sailboatmike
I have chased some prices down for torsion suspension
I can see why our friends in the USA just bang on an extra axle, its only a few hundred dollars, here in Australia its thousands
Single axle 2000Kg assembled with 6 stud hubs and hydraulic disks is $1430 you just have to pull off what you have and bolt the new one on - BUT its only available in Landcrusier 6 stud hubs
Tandem axle (1250Kg ea) are $1320ea so $2600 for the pair and are available in ford or holden stud pattern - tandem axles have to be rated an extra 25% so the 2500Kg will give you 2000Kg rating
Thats from Transtyle in Melbourne - 03 9775 1762
Huntsman dont do Torsion suspension
Neo
Post by Neo »
Hey Mike, did you check out these guys?
http://www.factorydirecttrailers.com.au ... -trailers/
They have a listing on GumTree
http://www.gumtree.com.au/s-ad/bairnsda ... 1058788656
Neo
Post by Neo »
Neo wrote:with just one small bow bunk, one big middle bunk and two bunk pads (port and starboard) at the back.
Hi Tom, Sorry to mislead you ... there is a third bunk at the back too :)
sailboatmike
Have you seen this one Neo, 2800Kg Tandem kit
http://www.ebay.com.au/itm/DIY-trailer- ... 2119657428
Neo
Post by Neo »
Nice find but I'm not so keen because...
I'd like Disc brakes ... Can't bear the idea of those drums in the salt water .... Consequently I can't have electric brakes :( ... Does anyone do an electric solenoid that pulls the handbrake lever? ... Or is that too simple!! :?
In my case it's cheap to buy the metal axles from a metal suppliers and have drop axle stubs welded on.... Can wrap that up for $110 an axle.
I'm thinking that the only affordable way to do this is to put together all the parts and metals and make a 2600 GVM trailer myself but the breakaway brakes are the show stoppers.
All the best.
Neo
Neo
Post by Neo »
Ok here's the updated drawings
Image Image
Download the pdf here ... https://goo.gl/1f9gcZz
All the best.
Neo
Neo
Post by Neo »
My Bunks are made of what looks like constructional pine covered with a blue nylon strip. Surprisingly the wood doesn't appear to be rotting away but I would like to change to another material if I can.... Something more flexible, so under the weight of the Mac it flexes to the curvature of the hull.
Any suggestions on what I could use?
All the best
Neo
