Brake issues Titan model 60
macowneril2015
- Location: Downtown Chicago, 2001 26X, 2001 50 Hp Nissan (NS50D2)
So i finally got the parts to replace the spring, shock absorber, and master cylinder for the titan model 60. I replaced the parts but now i cant push the actuator part in.... i tried backing my truck up, nothing I take it apart and everything looks right. I put it back together the same way I took it apart. I have not connected the brake lines so there would not be a pressure issue. Another issue is the spring part appears to be a little long but I believe I can adjust it using the screw on top. The issue appears to be maybe tied to the shock absorber. Any help or suggestions are appreciated. I am going to try again today yesterday i spent 4 hours replacing and trying to figure it out.
- RobertB
Re: Brake issues Titan model 60
Post some pictures. BTW, after doing the blocking the trailer wheels and backing up the tow vehicle to bleed the brakes, I learned the easy way - tie a rope to the trailer jack wheel and to a 4 or 5 foot 2x4. then use the 2x4 to lever the coupling in.
macowneril2015
Okay I fixed the problem now the bleeding the brakes is an issue I tried using a vac hand pump and the pressure won't hold I am not sure if it is an issue with the bleeder screws or what but if anyone has suggestions or experience I appreciate it.
- cptron
When I helped Vic bleed his brakes he had an access whole on top covered by a plastic/rubber insert. Remove insert and you should be able to have someone use a screw driver, or something similar, and push the actuator in to pump them up and hold while you then work the bleeders.macowneril2015 wrote:Okay I fixed the problem now the bleeding the brakes is an issue I tried using a vac hand pump and the pressure won't hold I am not sure if it is an issue with the bleeder screws or what but if anyone has suggestions or experience I appreciate it.
Hope this helps.
