26s lines led aft double spinlock question
Im working my way through installing the hardware for lines led aft on my 26S. I have an XAS spinlock double clutch and I cant seem to settle on a location for it. If I go inside the winch it will most likely be very close to the winch with a chance for interference with the winch or winch line. Not that Ive ever really needed the winch for the stock jib I use, but one day I may up the cash for a furler and then it might become more of an issue. Same with mounting it outside the winch, it could interfere with the jib sheets and factory rigging that I still use. Suggestions?
- mastreb
Re: 26s lines led aft double spinlock question
Forward of and outside the winch? That'll get it well away from the winch but still easy to reach.
