Replacing the Bow pulpit on a Mac 26X
Hi, I'm replacing my banged up bobw pulpit with a new one on my Mac 26X. I removed the smoked plastic cover from the bow ceiling. Do I get to the nuts be removing the Styrofoam in the ceiling of the bow, below the anchor well? Thanks, Bob
- JohnCFI
Re: Replacing the Bow pulpit on a Mac 26X
Yes Bob, if it's like mine was it should all be in little(ish) blocks, comes out real easy after you get started. Messy though, and a bugger to put back (I had some left over)!!
It is a bit of a stretch to get at some of the nuts.
While you are in there check the nuts underneath the cleats, mine had no washers, I wound up putting in extra backing plates for strength,
I also installed a big old fashioned 'T' Cleat as I found the stock cleats to small for much more than a bit of string!!
- dlandersson
Will it be chrome?
bobherk wrote:Hi, I'm replacing my banged up bobw pulpit with a new one on my Mac 26X. I removed the smoked plastic cover from the bow ceiling. Do I get to the nuts be removing the Styrofoam in the ceiling of the bow, below the anchor well? Thanks, Bob
