I tracked down my water infiltration to the seam under the rub rail. I poked at the seam and there's only about 1/8" of caulk in the seam which has deteriorated to where I can pull it out in strips. I can slide a utility blade all the way through the seam with ease.
I'm reading about how hard it is to replace rub rail. I'm confused. My rub rail is just a piece of rubber. It has the same cross section of what I've seen from bwy, but it is not hard to pop on or off, its more or less inner tube... Just thick. Clips on to the bolts. Very flexible.
Is the factory style rub rail more of a vinyl?
Also, I find conflicting recommendations. Is the rub rail glued, not glued, top only or top and bottom?
Would it work with my rubber type to 4200 it or would it just stretch and rip caulk?
I was going to pull out as much of the old caulk as possible with a hook and maybe wire brush and just caulk it best I could, leaving my rub rail to be clip on only.
I'm terribly ignorant when it comes to boats. Am I way off base?
Thanks
