Yeah don't envy you blokes up there right now but hope it ends up better than the last time the dams that wn't fill again flooded
Funny you mention the ELCB's as being "new fangled" when I was an apprentice and could take you to exactly where the old house was because it made an impression on me, I asked the boss what this strange looking old box was on the swbd panel and he explained how it worked but said they were just too much trouble as they kept tripping, but to me they seemed a great idea, much better than the MEN system elsewhere.
A couple of years later a contractor from Griffith came around trying to install newer ones and eventually the county council banned them and they all had to be removed due to the nuisance tripping and call outs for the supply authority but found some still going years later.
There was a nuisance tripping problem especially with old houses with conduit with VRI and rubber insulation but then they came out again later along with circuit breakers, as a contractor wiring factory built housing I was one of the first on board with them, they are a great idea but the first ones were too far before their time (20 yrs) now they are compulsory?.
IMHO they are a much better fire protection than fuses or were before double insulated devices and especially in toasters with wet crumbs, even back when they first came out and I have no idea when that was as it was before my time but they are definitely a life saver.
From my experience most fires have been caused by loose wires eg of one where a light was flickering in a toilet comes to mind, the switch terminals were loose and the twin active had burnt right up the wall to the top plate but seen many behind pp's with even small loads.
One where fuses including a HRC didn't protect the front of a house was where a neutral screened cable with the inner active conductor rubber insulated had been crimped or damaged going through a stud to the meter it was obviously not enough to blow the small hrc 35 amp service fuse and another on the pole before the front of the house caught on fire, interestingly the heavier one on the pole blew first, there is a technical term for why but that was a long time ago too.
Interesting that hybrid circuit they show fuses on the battery (main fault current power source) but not on the diversion load? unless the controller incorporates it, I see they basically use an MEN system obviously because there is metal conduits etc but unless incorporated no fuses from the generated power sources which can also generate high currents ?(possibly inbuilt?)
