porthole replacement - forward deck
judith ann
Post by judith ann »
i am looking for a replacement for the fprward porthole, the one on the forward deck for a 26 x. any ideas i loooked but the only results i got were for a custom made one?
Hamin' X
Re: porthole replacement - forward deck
Post by Hamin' X »
Give Gail at Blue Water Yachts a call. They have exact replacements available.
judith ann
thanks will try.
judith ann
rich thanks you are right, great site.
Hamin' X
Post by Hamin' X »
My pleasure. :)
Egress
Post by Egress »
just replaced both my "front windshields" with BWY windows. make sure to remove all old sealant and prep original surface. Also since there is a "bow" in each window you will struggle some to line up all 6 holes so suggest inserting finish nails into each hole to align and then using screw bolts from original or replace with stainless. Just install each screw nut initially only finger tight and then use a star shaped pattern and tighten the rest half turn at a time or so. This will give you good watertight install. Good luck and don't worry this is relatively easy. Have a helper available as job will go much easier. I used masking tape on all surfaces to aid in an easy clean-up. 99 :macx:
Hardcrab
Post by Hardcrab »
Just curious now, but the front ports on my M are two different shades of tint.
The stbd side is more a purpleish color that the greenish port side and as the rest of the ports on the boat.
Can't really tell the difference from the outside looking in, just inside looking out.
Do yours show the same differences, or do I have two different lots of plastic from the factory?
No big deal at all, just wondering.
fishheadbarandgrill
Post by fishheadbarandgrill »
Egress,
What product did you use as a sealant/adheisive?
Bob
