Mounting Magma Gas Barbecue Grills
Mark Prouty
I have one of Magma Grill from a previous boat. If anyone has one of these, where have they found is the best place to mount it?
We mount ours (on an X) on the starboard rail just where the lifeline connects. Most folks put them on the stern rails, but we found we didn't like climbing over all our guests and the steering wheel to check the burgers. Mounted up front we can pop up and down to the cabin to prepare the rest of the meal. After the meal we remove the bargeque, but leave the mounting bracket on the rail.
Depends
I have used mine in the same spot as Tom Spohn posted, but also have had it on the aftmost stanchion. It depends how people are on board, whether I have the Bimini up, whether I have something else on the stove inside the cabin and am running back and forth, etc.
I find it is no trouble to take the mounting bracket off when I put the grill away, so I just keep my options open and go with the flow
- Andy26M
- Andy26M
Good advice. I just got one for my birthday from the Admiral (spouse). Was wondering if the sheets get hung up on it on the starboard rail. Was anticipating putting it on the starboard rear rail. I'll yell at the kids to check the burgers/brat (although they might roll off if we end up riding the trough).
Any hints on operation or is it pretty straightforward?
BG
1999 26X "ParadoX"
Channel Islands, CA
BG
1999 26X "ParadoX"
Channel Islands, CA
Mark Prouty
Another grill to look at.
This is kinda off topic but another grill to look at is the SI Port 2 sport BBQ at www.sportbbq.com I purchased the extreme bbq and love it for 2 reasons:
1. hinged lid. Looks great and is very functional
2. Pot rack. You can use this bbq as a stove or oven. I have a 2004 M so I prefer to do my cooking outside.
The BBQ's are made in Canada. Just something to think about.
KRV
KRV
Well, first overnighter on the ol' 99 Mac26X. The Magma Grill didn't work too well due to the chef's menu recommendations. She wanted Top Ramen. I tried to boil water on that thing for 1/2 hour. Didn't get much warmer than Luke. I finally poured it out into the cockpit to scrub the floor. I think the Magma is have been much better for burgers, or other "flat" food. lol. We were just rolling too much and the pot was sliding all over the place.
Mounting, lighting were a breeze.
Thanks for the info on it.
B
B
- Scott
- Sailboat: Venture 25
We also put ours on the frontrail, see pic. It clears the sheets pretty good there, never in the way on or below decks. The cover fell apart this year due tu UV's, I gotta make a new sunbrella one. Ive moved it to the other side though as that is the side I pull tight to the dock and I can stand on the dock when Im cooking in the slip.
As for boiling water, it works better if you remove the flame cover (the 4" disk that covers the flame) Then it works like a gas stove.
Mark Prouty
- Duane Dunn, Allegro
Our's is on the starboard stern rail, it works well there. It is never moved, why put it somewhere you have to mess with for sailing or anything else? All we do is slip off the tank/regulator and put the cover on it. We use it along with our aft BBQ table. I just recently built a little rack on the transom that holds the tank and regulator and a spare tank. I changed the table mount recently and don't even have to lower the rudder to put the table on any more.
Here's the mod that shows where it is
In that position it is behind our enclosure and even in rainy weather all we have to do is roll up the back panel and cook.
Unlike described above, ours works great also as a stove. On the trip we had trouble bringing a very large pot of water to a boil on the inside alcohol stove for the 3 crabs we caught. I popped off the grill and the burner cover and set the pot on the BBQ, it quickly brought the water to a boil and cooked the crabs.
I changed the table mount recently and don't even have to lower the rudder to put the table on any more. I also added a mount on the forward side of the galley down below and on the back of the forward dinette seat. Now the Third mate table can be placed in any of those 3 places. The one on the galley doubles the available galley surface as it extends forward over the settee and also is a great place to set the laptop for movies so everyone at the table and vee berth can watch the movie.
Mark Prouty
