I'd been making good progress close-hauled to a 10 kt wind with one reef in, then the wind picked up to 12-13 kts. This started pushing the heel angle to 30+ deg. at which point I felt the boat was behaving like a (very large) dinghy.
Beyond a certain angle it just looses all steering, and from a side-on viewpoint turns hard towards the keel - i.e. into wind. It seems to me this is the effect of centerboard drag together with loss of steering because the rudders are no longer vertical in the water, just what you get in a dinghy if you can't hold it flat enough.
Ideally I should have put another reef in, but as I was nearly home it wasn't worth the effort so I just carried on in what must have looked like an interesting attempt to emulate a snake.
I know some aspects of weather helm can be a case of sail balance, but I don't think that's the case here, this felt entirely like hull dynamics. Some boats use cambered rudders to keep the in-water rudder more vertical at high heel angles - just musing on whether anyone's done that mod to a Mac (and if so does it work).
I'm curious as to how you guys who report heeling at 40+ deg. have kept the boat in a straight line. Or is there a difference between X & M here?
Any ideas on dealing with the problem, or is it like the old joke: "Doctor, I keep rounding up when I lean over" - "Then don't lean over".
Cheers, Rick
