Ah.... I understand Catigale's comment (I think). I have been using the wrong term saying it was like a "U joint". A U-joint permits two rigid rotating shafts to have limited angular freedom of motion from each other. Catigale doesn't see any rotation here and he's correct.Catigale wrote:
Also, does the toggle allow the lower mounting point to twist with respect the upper hole ? It doesnt look like it, and if it doesnt, I dont see how it changes the lateral forces on the stay- other than rotate the thimble by 90 degrees....maybe that is the key...
Ive been sailing 10 years without one on my CDI FF2 btw...![]()
It's been a long time since I took intro to mechanics and I don't use the right terms.... my bad....
Lemme try again
Using a toggle at the top of the headstay allows limited freedom in translation (not rotation) in the X, Y, and Z planes between the hounds. I think the correct way to describe that is "three degrees of translational freedom between the forestay and the hounds. "
Using a toggle at the top of the forestay converts any angular misalignment between the forestay and the hounds into lateral and vertical translation which occurs at the pins in the toggle and hound.
The mast is not at all rigid, and the forestay is quite flexible... The forestay and mast are constantly moving relative to each other.... whence cometh the problem of how to link them
With a toggle at the top, the wire rope doesn't flex sharply at the swage or the top of the furler extrusion (which breaks wires over time); instead, the toggle permits the swage to move in translation (absorbing the lateral forces on the forestay wire)
Okay, is that as clear as mud? Have I mangled the terminology again!?!
Judy B
