Interior access panel mounting hardware question
cpost
Post by cpost »
I have a 2004 M and starting to look at doing some simple mods.. I've noticed a lot of access panels throughout the cabin that are just held in with what looks like stainless steel sheet metal screws .. some of which are stripped and have fell out... does anyone know of a better solution than sheet metal screws? Maybe some sort of "insert" nut?
kziadie
Location: "Sundancer" 2006 26M Honda 50 MACM1338C606..... BAZS-3601239..... Central Chesapeake Bay
Post by kziadie »
Dont know about inserts, but using a dab of silicone on the threads works well to lock them in place without being too agressive if you ever need to pull them. If the holes in the liner are damaged or worn you may need to use slightly oversize screws.
Kelly
Wa2paa
Location: Burnt Store Marina "Punta Gorda Florida" Odin 820 "Mast28" w/Honda 75
Welcome
Post by Wa2paa »
Hello to Cpost,
Just would like to say hello... I am @ Shouth Shore Marina on My boat "Kapona" pop in and say Hi when you see Me working.
Best of luck, with your "M"
Captain Jack & First Mate Carol
Note: First Boat when you come in the gate..
cpost
Re: Welcome
Post by cpost »
Wa2paa wrote:Hello to Cpost,
Hi Jack.. I remember you responded to my post about South Shore and everytime I pass your boat I tell my wife .. "that's one of the guys on the forum".. Next time I see you on your boat I'll stop by and say hi... maybe you can give me a few tips on how to get in and out of the slips at South Shore.. I haven't hit anything yet but I can't say I'm not in a "panic" state when I approach the slip from a day out on the lake... You have a very nice boat by the way .. is it longer than a Mac or does it just seem like it is sitting on the trailer?
James V
Post by James V »
Get some 1/8 fiberglass and cut into 1 inch squares. Glue with 2 part epoxy and clamp for a few mins. Pre drill holes. this should hold for a long time.
Mine did the same.
Jack Sparrow
Location: Cairns, Australia 2007 M 50 Yamaha Run to Paradise
Post by Jack Sparrow »
For panels that have to be removed often I use those s/s clips that are used to hold speakers in panels. I re-shape to clip and epoxy it in position.
Jack Sparrow
