I still firmly believe that it is not only power, but the angle of the transom that keeps the Mac in a predominantly nose high attitude. This also affects the spray pattern oberved by some.
In that pic of XX, it would appear the boat has just hit a wave, causing it to look as though the spray pattern is far aft and the front half of the boat is well out of the water. I suspect that it would not have looked this way had the pic been taken cruising along on flat water.
I can easily affect spray pattern with my M just by triming the motor up and down. With lots of weight up front, wedges, and trimmed full in, the spray pattern is far fwd. I can move that all the way to where XX has it in the pic just by tilting the motor up.
Look at how far back the center line of the wake is behind my M in this video, as well as the spray pattern being about half way down the boat.
Oh, and a tip for viewing videos online, pause it and let it fully load so it plays smoothly after you hit the play button.
The Bow is down, the boat is planing, I can see where I am going while sitting down, the boat stays fairly flat while in a mild turn, all good things IMHO.
