I have not investigated further, but I am afraid I will need a new lower unit or at least new gears, etc. I have been studying the Honda Service manual. It seems that when you move the shifter the vertical shaft pushes a 'pusher rod' that moves the gears horizontally back/forth. The vertical power shaft is always spinning in the same direction and the reverse gear is on one side of it and the forward gear on the other. So, my guess right now is that without gear oil, it heated up and fused together or something like that, so that now when I shift it cannot disengage from the reverse gear.
Now my question is what happened to the gear oil? I'm not sure how to check where it is leaking from. I was thinking many of the gaskets, etc. are cheap, so just replace all of them?
Of course, I may need to buy a whole new lower unit! I have not yet found a reliable and knowledgeable Honda mechanic, and here I am in Miami where there is a year-round boating season! You would think there would be good marinas/marine mechanics around who would work on a Honda.
My wife suggested I could dock and do everything in reverse and worry about the engine later
The Honda causes me nothing but maintenance headaches and maybe now some angina. The only upside is I've become a much better mechanic.
[mod]ModEdit: Moving to P&T ~fc[/mod]
