Finally 95% of dramas are over.
Last is getting the trailer to meet Australian Standards, then a Saftey Certiifcate for it, then registered for road use.
I can see a couple of major problems looming with US trailers already, and it is not going to be either easy or cheap, but "we will overcome".
Fortunatey my gateway is a very wide 'double' as I have large trucks in and out all the time, plus have 6" thick concrete.
I have always kept an area 'free' for my toys, maybe 25m x 60m, so that is where it went.
It dosn't have "goal posts", and from what I saw on that video, they seem an important piece of equipment.
Am I correct in this assumption?
Next question.....it does not have a 'drivers seat'.
I see there is an indent in the 'glass' in that area (both sides) so is that where the seat fits in?
What does an origonal look like.
Won't take the chippy long to make something, so long as he has an idea of size etc to follow, and any quirks re fitting.
Couldn't believe how this truck 'worked'. Very interesting to watch.
Driver had the boss of the container yard volunteer to load it for him with a container fork lift. Took all of 2 minutes.
Gave this guy a case of beer when we went out to put the axels on etc, and the assistance then and since has probably saved me a big K.
(See the old F100 in the back....it turned up from painters a week back, and am I'm deep skippy droppings with the wife at the moment......she wanting a new patio....which she has to wait for)
This is the mess. Keep in mind, we had to clear a lot away to be able to get in.
I am told it is Quarantine.....just took everything apart, and left it. Probably taken and hour to sort it out.
I am guessing that methyl-bromide has left a sort of fine soot over everything.
Will put the casuals on to cleaning it next week. Will be all over in under 2 hrs.
Outside is not pretty. The plastic protective layer they wrapped it in has left as lot of 'sticky' patches, but that will come off quickly.
The black paint (not bottom coat) is dull.
If I just put one of the workers on it wth boat polish and the buffer on the end of the power drill - will that fix it?
I know that has bought up the fibre-glass on past boats.
Just wondered about the faded black.
Will shoot a coat of bottom coat over it too. That's too easy.
I was surprized to see blue vynal-type material on the swabs, and white on the dinette seas and other seat opposite.
Is this normal, or has it been replaced?
Personally I prefer this material to the 'cloth' ones, so no issue, just curious.
Now for the table.
It has a sort of rough surface, and as you can see, although functional, could be made to look a lot nicer.
Looks a bit tired and worn actually.
Anyone had this problem-situation before, and how did they approach it.
Outside of toilet door is the same.
Front of galley is same, bit rough, seems like a piece of 5 ply. Pretty obvious it is a replacement 'front' which has an electric fridge and a microwave set in to it.
First thoughts tell me to paint with a high-gloss enamel.
The carpentry has been done very well.
Any opinions?
OK...we have 2 pipes here.
Havn't had a real close inspection, but small pipe goes to a nice fitting on outside saying water.
Is the other for pumping out the porta-potti, and if it does, just how do you do that.
And this one is just to prove it is not an Okker-job.
Also noticed, it has a 12v pressure pump with pipes to basins and shower from what appears to be a defated blue water bladder under one dinette seat.
Is this standard for a Mac or an addition?
To summarise
The best bucks I spent, were those on the 'Surveyor'. He got it right all the way thru.
I am perfectly happy with the dollars I spend and what I got.
The extras are invaluable.
jib, genoa and all the sailors extras.
Radar, Chart Plotter, Depth Sounder, new VHS and Radio/CD, new Bimini (jeez, better check the colour).
May sell off the marine BBQ.
I feel if i put the staff on to it, (4 plus me) by the time 4hrs is up, it will look pretty good.
The glass on the inside is perfect, and the 'bungs' throughout are obviously for ecectrical fittings.
Seems to have 3, if not more, batteries. Will sort that out later.
The paperwork in the boat is interesting. There are 2 Bills of Sale, one from Millenium as new, then one in 2004. Everything is there, invoices, warranties, booklets.
That Roger MacGregor makes a Blxxdy good boat for the bucks he charges.
Will be back to you over the trailer - big issue looming there.
Thanks for taking the time to read, sorry about the length of this.
Phillip
