opie wrote:FrankC - Can you do the same thing for the Honda BF50A engine regarding prop selection and details that you did in this thread for the other engine?
opie, all I can do is look at Honda's website & repeat the basic specs for your Honda 50 ...
- WOT range is 5500 to 6000 rpms
- Gearing is 2.08:1
- Max prop is 12" diameter
None of this tells exactly which prop or what pitch will be best, for your specific loading of food/water/equipment. Your boat will undoubtedly need a prop pitch from 9 to 11 inches depending on those variables, but first you need to buy one and try it. If it gets into that "magic range" when wide-open, then it's good for general operations. Since you've never done this you might try to find a friendly dealer who can guide your testing - and provide some test props.
Guys who are very prop-saavy might later tweak their choice to improve some operating parameter - better economy, better planing, better for towing toys ... fine-tuning the blade profile or pitch to maximize in a narrow performance category. But that's fine-tuning.
But first, we all need to pin down the "gross-tuning" for our particular installation by trial 'n error. Buy a prop between 9 and 11 pitch & see how it performs.
Most of us find some problem with the first prop test, like can't reach the upper rpms, or spins right past the upper rpms. Based on results, exchange for a different style or pitch and see if it cures the problem.
Incidently, a "dog-eared" prop is another way to describe a "pontoon" prop.
Sorry, can't really help beyond that, except to suggest you PROBABLY should first try a 12-inch prop (approx diameter) with a pitch in the range from 9 to 11 inches (either of the last two props you cited). Choose a lower pitch if your boat is particularly heavy.
Read all archived posts by Robert on the propping of 50-horse motors. Read them AGAIN, make notes, and try very hard to completely understand Robert's advice on various operating parameters of the smaller engines - you'll save lots of test time that way.
