1. steaming/foredeck combo light. I searched several old posts and see that several Macsters have replaced with this (or a similar) model but I can't seem to find any place that sells it. I suppose I can ask WM to special order it, but that is always a pain. Here is what one from aqua signal looks like:
Anybody know of a shop (either B&M or Internet) that sells this light?
2. New topping lift - the one that comes stock with the boat seems to be a few feet too short. I'm gonna buy about 28 feet of 1/4 inch yacht braid instead of using the old line which always had to be concatenated to another line to work right.
3. My windex vane broke off so I figure I may as well get a new one. The new ones come with the bird spike on the bearing screw so that is probably a good improvement. WM has a 15 inch windex for about 50 bucks. Anyone know a cheaper place to get one?
4. Looking at the mast yesterday, I noticed that the steaming light seems to be attached with aluminum rivets where as the gooseneck is attached with SS rivets. I got a rivet gun from an autoparts store that is supposed to do 3/16 rivets but I saw from other posts that this may require feats of strength. The real question is should I get a new gooseneck while I am at it? The old one got loosened in the accident and is slightly bent now. I bent the tangs back a bit but if this weakens it, then maybe its better to wait for a new one to arrive. I've seen a few posts about broken goosenecks.
5. I'm wondering whether its worth spending the extra money for an LED anchor light. While I am at it, I'll rewire the new mast with a 4 conductor wire and put a new deck connector in. I'm figuring one conductor for the anchor light, one for the steaming light, and one for foredeck light. Should I also get some spreader lights to light up the cockpit? And should this be on the same circuit as the foredeck light?
6. I'm still debating about whether to replace the standing rigging. After inspection, the original rigging looks fine, but the tang which attaches the lower starboard shroud is bent some (60-70 degrees). Pretty easy to bend it back in a vise, but will that lower the strength significantly enough to be worried about it? Probably not a good idea to replace that one shroud alone as I think I should at least do both the lowers, or just replace all four.
7. And last but not least, I thought I may as well get a new (4 inch shorter) forestay and turnbuckle. There is nothing wrong with the existing one, but hey, while I'm doing all this other work, you know how it goes. Should I yank the old one out of there and take it down to a local rigging shop or have people had good luck with any mailorder (Internet) rigging shops putting one together? I figure its also good to increase the size of the wire to 3/16 and put as big of a turnbuckle as will fit under the FF2 furler. I'm also assuming that the wire is rigid enough to just push it through the furler, without having to use any special "fishing" tricks, is this correct?
Sorry so long, but lots of questions. I hope you guys who have experience with these issues can give me some advice cause I hate doing things the wrong way. Thanks in advance.
