Daniel (and anyone else interested),
Here are the pictures of how I trailer with the boom connected.
First the mast is lowered with the boom connected until it rests in the mast support. That is Dad (my current sailing buddy) on the crank and me guiding the boom down. The mast has about a 40-45 degree turn towards the boom and the mast is laying on an angle in the mast support and on the cabin top. The boom also comes to a rest on the port side of the cabin top.
Then the pivot pin is removed and the mast is slid forward about 4 feet or so. That is all the further that it can go due to main halyard and main sheet being extended as far as they can go.
When the mast is as far forward as it can go the spreaders are still in the cockpit, just behind the cabin entrance. The lifelines on the sides of the cockpit are disconnected to allow the spreaders to rest without stress. There is no weight on the spreaders as the mast is supported by the mast support and laying on top of the cabin.
The mast is secured to the mast support (and to the bimini top) with a strong bungee cord (double wrapped). I cannot move the mast when this accomplished. We use bungees and ties to secure the furled foresail and loose lines to the mast about every 4 feet or so.
Notice also the distance the mast hangs off the back of the boat. It is about 9 feet from the mast end to the engine. I would hang a red flag or red light if trailering on the open road.
What I have not yet done but have sort of determined on my own is that the next time I trailer I will tie the bottom of the mast on both sides to the stanchion behind it sort of like a spring line to keep it from going forward and hopefuly from side to side. I will also tie down the mast at the mast support to the rear cleats to further secure it when trailering (not sure if it could bounce and pull the mast support out of its supports on a bumpy road).
I know some of you won't think this is a good plan, this is how my PO set it up when put on the "all lines to the cockpit mod". It trailered perfectly fine from Tampa to Jacksonville (5 hours on the interstate) and sure seems to make set-up and tear-down much quicker and easier than removing the boom and main sail every time (although I must admit I have not yet done that so I am not speaking from experience on that issue).
Sorry for the long post. Can't wait until I get a slot in that dry storage lot right behind the boat. That lot is only about 100 yards from the ramp and there are no power lines in the way. Most folks in there leave their mast up. I have to go to another lot about .7 miles away.
Let me know if anyone has any questions or comments.
I appreciate all the help and advice (both directly and indirectly) I have recieved from all the fine folks on this forum.
(Mod note: I fixed the code so your last picture would display properly. KBM)
