I've been checking the boat now and then, with the slow charger on the battery and a small heater on low setting to keep it dry. I've notice two very small areas of drip accumulation, one under the left front skylight, and the other at the lowest point in the wire bundle that comes out of the pedestal. It could be condensation, but it seems there is a slight amount of moisture there continuously, the drip rate is very slow.
Is this normal? I'm a new owner, I'm wondering if this is something that can be quickly and easily sealed up with a small amount of silicon putty or something. I'll check what seals I can on the windows with a hose (or if it keeps raining
