It seems like most likely candidate is a ballast leak since Ive inspected the hull from outside and cant see any damage issues...
Anyone have any experience on the
ON edit - summarising thread - after testing ballast and hull found no breach...leak is most likely overlow from ballast valve with loose plug
On edit Sep 2007 - found leak source was badly corroded compression post, probably due to electrolysis.
On edit May 2012 - the compression post was found to be composed of stainless steel on one end and mild non-stainless steel on the other - the corrosion was inevitable for this material.
