This saga started about 6 months ago. One weekend I was out running the motor pretty hard tubing with the kids and everything was fine. About 2-3 weeks later, I went out with my daughter and it started overheating, it has been trouble ever since. Coincidentally, my depth sounder stoppped working about the same time (meaning I have probably been in too shallow water kicking up dirt)...and...there was a big mud dauber party in my boat about the same time when they got in and mudded everything up. I've come to the conclusion that I have multiple obstructions in my motor, maybe from the bees, maybe from the Bay silt and sand, maybe from both. To make things even more complicated, these obstructions may be moving around.
The first thing I did was replace my 5 year old impellor. The one I took out looked almost as good as the one I put in. The motor did not overheat on the ear muffs after 10 mins or so, so I put it back in the water and it started overheating again. After the salt away treatments, I put the boat back on the trailer and took the lower unit off again (I have had the lower off 4 times now trying to fix this). Now it was so bad I got the overheat warning just idling with the flusher muffs on. When I shoot water up the copper tube, only a trickle was coming out the exhaust pipe but good pressure at the tell tale. I pulled the thermostat and shot water up the hose again, only a trickle out of the thermostat hole. I flushed back and forth for about an hour using house pressure. A big sucking sound happened and then my flow got much better. I figured I got a sand clog out. After this, I noticed that I was getting more water around the exhaust pipe...but still hardly any through the exhaust pipe itself. The motor was not overheating any more on the flush attachment. Even revving it up a bit. So, I figured I must have fixed it!......NOT
I put the boat back in the water and as soon as I get a bit of load on it in slow speed....beeeeeeep...damned whining overtemp noise. Shut it down again and put it back on the trailer today....again... Tomorrow I will pull the water jacket cover off. Seems to be my only hope that those passage ways are all bunged up. I was holding off doing this since Mercury wants like 30+ bucks just for the stupid gasket...and a 3-4 day wait to boot. This is my last shot at DIY, a couple more hours and I give up. If its not an obstruction in the water jacket, then probably the whole powerhead has to come off and everything will have to be cleaned out....at least that is what the Merc shop is saying as I have been consulting with them on this issue.
Motor is still running well and when the alarm goes off, I shut it down a bit and let it cool off...so, hopefully I have not done any serious damage to the powerhead yet although on second thought, maybe a good excuse to upgrade to a larger motor
Any mechanics out there have any tips about how to rod the passageways without removing the whole powerhead? I figure that is about all that is left now is the water jackets so it will be interesting to see what it looks like in there.
Another difficulty in all of this is that the shop manuals (both Clymer and Mercury) do not seem to show the whole water flow diagram so it is very difficult to figure out what passageways go where. Tonight I went to a bookstore and they did not have a single book on outboard motors.
