I have a '95 X, number 851. It is fitted with the centreline ballast valve under the companionway that is meant to be the main means of filling, and is the one that I primarily use for this job since running back to close the gate valve with water pouring over the cabin sole doesn't appeal.
Poured some water into the tank and went under to find it dripping happily out onto the driverway. Also noted that lots of mineral staining that seems to suggest that this isn't a new thing. I pulled the valve out and took a look. There was a bit of pitting in the rubber seal, so I cleaned it and flipped it over so now there is more, or less fresh meat to seal against the hull. The rubber itself is still flexible and shows no signs of hardening. Then I took a look at the seal plate and noted that it was slightly concave - that is, it was bent up in the middle where the threaded rod pulls by about 1-1.5 millimetres when viewed against a straight edge. I straightened this with a heavy hammer and refitted the whole thing. Water goes in, water comes out -slowly, but it still comes out. It seems to be comming from the front part of the seal plate which seems to sit a bit proud of the boat. Spinning the plate 180 degrees makes it worse.
One other thing that I noted was that there are two set screws welded to the plate, over which the rubber seal is placed and lock nuts over that to secure the rubber. Evidence marks on the rubber face showed that one of these is not in the right place in relation to the filling holes in the bottom of the boat. In fact, it is so off-centre, that it seems that the washer under the lock nut overlaps the fibreglass. Thinking about the area of the seal and the nature of the underside of the boat, I don't think that this is the problem.
So where do I go now? The options appear to be:
1. Order a new valve and hope that fixes the problem
2. Take to the boat surface with some coarse paper and see if that helps
3. Replace the rubber on the seal (anyone know how tight the locknuts ought to be?
4. Glue the whole thing down and never open that valve again
I would greatly appreciate any thoughts, or previous corrections that folks may be able to provide. (just don't tell me I shouldn't have straightened the plate
