Get one of these:RichandLori wrote: Day 1:
13.7 Gals of Gas at Marina (yikes) $38.09
Yanmar Outboard
Power it with:
biodiesel
I was forced into buying a 8oz bottle of chemical at a WestMarine in the Harbor....man did I over pay! That's like $1.25/oz....but when you are out...you are out...if you know what I mean.Moe wrote:I hope you didn't use $10 worth of chemical.
Exactly! It sounds so easy....unplug for a few years...sail around...you sell the idea to the Admiral and them BOOM reality sets in! Once you start reading though the pile of guides, hrs on the net, making budgets, ect, it isn;t as easy to pull off as you think. It actually takes lots of planning and preparation to pull it off! Our cast off date is probabally on the agressive side and might be pushed back due to the realities of life, and I'm not the type to panic if it gets pushed back. I have found already that the actual journey is key here.....the way it makes you think about things...the world in general...the things you realize that are important is key.Moe wrote:This does point out something with regard to your dream of long term cruising. .
