That's exactly right Craig. It's a very tight squeeze. I assembled mine from raw parts and it was QUITE a chore. I don't think the rack itself could be modified, but you could probably switch to a rotaty helm steering systemand make it fit, but I'm not sure you'd want to. From what I understand the early X's had these helms and they are not nearly as strong -- consequenlty more prone to failure.edurbin wrote:Arhh, I see Zavala (as much as I can with not having pulled mine apart). The rack must go down some way into the pedestal tube. Suppose the pedestal only is rotated, could the rack attachment be modified to reattach in some way. Then, suppose I had to make a new box for the steering wheel and outboard connections. Might that work ? I guess that steering wheel is not straight up and down, but is the steering wheel shaft perpendicular to the rack ?
Now, not wanting to be pessemistic, here's a thought... What about removing one of the fuel locker covers and "sliding" the current pedestal to starboard or port? You'd free up floorspace, but give up the locker and some seating?
