Water flow from coolant hole - How much pressure
Hey,
What sort of pressure should I expect to come out the wee holes on a Honda 50HP motor. At low RPM's it is a slow dribble, and a constant low pressure flow at high RPM. Iwould think it would flow faster?
- richandlori
- aya16
also run a wire through the pee hole first, the salt and silt will build up there and give you a dribble if at all. how old is the pump?
did you ever run the engine without water running through it( flush hose)?
I see guys start their engines on the ramp before they put the boat in the water, gives me chills. If you ever did that then your pump is toast after the first time. But if your pump/engine is pretty new and you never did the above, I would guess the pee hole is restricted.
- Sloop John B
- Harry van der Meer
Mark Prouty
I have had some experience with this problem. I have a 16 foot runabout that can run in very shallow water if I trim the motor up and run full throttle. She'll actually scoot over water only about a 15" deep. Others slow down and get stuck. I live near the Wisconsin River and frequently scoot over sandbars. I can get to a secluded stretch of the river doing this.
On occasion, I misread the river and the boat gets stuck on a sandbar. When this happens, the motor will usually stop peeing.
Here is how I correct the no pee problem on my Mercury 70hp 2 stroke.
There is a little plastic insert with a small diamater hole at the end of the water line. Little grains of sand can block this. I always carry a strong length of wire to poke these grains of sand out. Most of the times this is all that is needed and will cure the problem.
After I poke the pee hole (that sounds painful
), she'll occassionally need to be started and restarted. The stopping and restarting creates just enough force to get the flow going again.
Even at slow idle, I should get a strong flow of water out of the pee hole.
- opie
As someone above said, 0n the Honda 50 there is a brass fitting on the engine that screws into the block on one end and has a barbed fitting on the other. The barb connects to the small black hose that leads to the plastic fitting on the cowl, from whence the indicator water stream should flow. My stream was strong, then weak, then stopped, over the course of several hours. I used a coat hanger into the brass barb hole and flow improved. Back on the trailer, I used a deep socket and removed the brass fitting. The screw hole was about 7/16 wide and it was easy to see a piece of scale that was about the size of a paper match wide and 5/16's long. Just the right size to block the water flow. My coat hanger action into the barb was just pushing the blockage aside for a while and not removing it. With the culprit removed, the next day (yesterday on the Cape Fear River) the water stream (pee) was the strongest I have ever had since I bought the boat in Sept. 2006.
- kmclemore
Many times insects have made small nests in my motor's drain tube, and hence the need to clear it from time to time with some construction wire. In fact, I keep a ready-made piece in my boat's tool kit for just that purpose. Also, the rubber hose - at least the one on the Tohatsu/Nissan motors - is very easily disconnected from the fitting inside the housing, so remove the enclosure and make sure it's connected inside. Not sure if that's true of Honda's, but it bears checking.
The stream, when correct, should look like a 20-year-old guy taking a leak after having a few beers - a steady stream. If it looks like a dribbling 70-year-old guy with prostate trouble, it's time to change the pump!
