Need Help getting black streaks out of the gelcoat
I have 5-10 marks on the outside white gelcoat of a 26x from rubbing up against newer tires at a dock. Anyone know what the best way is to get that out? Any info appreciated, thanks.
Chuck
Chuck
Solvent can preserve the shine
while abrasive stain removal will leave a less shiny spot that will show if you look at it at an angle.
I had great success with acetone recommended by my Mac26X dealer.
Whatever you use, test it on a small spot away from general view first to prove to yourself that it will not harm your finish.
Cleaning
Thanks guys. I'll try the acetone first. Good thing about that is that you can cut it with water since it is soluble in water. Then if it's stubborn, I'll try the Wd-40 in a small area. The baking soda seems like a bit of an abrasive and may scratch up the finish a bit. Will keep you posted on how it works out. Thanks again for the suggestions.
- kmclemore
Cross posted from the adhesives thread, and hopefully helpful?
Debond 2000 Marine Formula.
Marine Formula is a specially formulated, patented mixture that cleans and removes adhesives and sealants used on and in the boat.
USES:
Use Marine Formula to clean-up and remove these common marine adhesives and sealants:Will not harm: Gelcoat, Clear Coat, PlexiGlass, AwlGrip, Imron
- Cured 3M 5200 and other polyurethane adhesives
- Caulks & Sealants
- Black Rub Marks
- Most Graffiti and Overspray
- Adhesive residue
- Liquid Nails
- Adhesive Film from Duct and Masking Tape
- Wipe away excess spills of sealants and adhesives including 3M 5200
- Polysulfide Sealants
Bill at BOATS 4 SAIL
- Sailboat: MacGregor 26D
